2005 450X inconsistent idle
  • gbuteyn
    by gbuteyn » Mon Sep 18, 2006 3:48 pm
    bike ran perfectly last winter, went riding this past weekend and everytime I stopped the idle was high. At first I thought it was a pinched throttle cable but after confirming the cables were clear I just happened to lean the bike over and the idle came up again. If I waited several seconds the idle returned to normal. I am thinking because the bike sat for 4 months the floats maybe sticking, anyone have an idea.
  • Mr Smith
    by Mr Smith » Mon Sep 18, 2006 4:02 pm
    Any fuel running out the overflow hoses?
  • gbuteyn
    by gbuteyn » Mon Sep 18, 2006 4:37 pm
    Yes, but only when you lean it over
    Kilroy
    by Kilroy » Thu Nov 09, 2006 9:02 pm
    My '06 is doing the same thing when I ride. I just put the JD Jet kit in, red needle 4th position and 62main jet (because I live/ride at 4500' MSL) air box mods and pink wire complete.
    I can't figure out why it idles high, then settles down after about 20 seconds. I checked the grips and lines, but nothing in the way.
    Heck, this bike is only 2 weeks old and 48 miles are on it.
    Otherwise it runs like a raped ape! Thanks to reading many posts on here!
    Thanks for all the input from experienced CRF guys on here. This is my first thumper.
    _____ooO_( )_Ooo___________________________
    _____|_____|_____|_____|_____|_____|_____|__|
    ___|____|_____|_____|_____|_____|_____|____|
    _____|_KILROY_WAS_HERE_|____|_____|____|
    by JAWS » Thu Nov 09, 2006 9:14 pm
    I had the same issue after putting in the JD kit, etc. I opened the fuel screw more and it helped, but when I put in a richer pilot the issue went completely away. I had the 45 and went to a 48, but I live at 600' .
    by crfsonly » Thu Nov 09, 2006 11:33 pm
    irratic or hanging idle is usually a sign of a lean pilot circuit. if you can't adjust it with the pilot screw then go up one on the pilot jet and see if that doesn't help.
    by XGiant » Fri Nov 10, 2006 5:21 am
    Kilroy, welcome to the site! Glad to have another Oregonian, even if you are only on loan!
    Kilroy
    by Kilroy » Fri Nov 10, 2006 9:39 pm
    Great idea... I'll do some tinkering with the pilot screw.
    Also, thanks X-giant. Our group is planning a trip sometime soon, or after spring to Huckleberry Flats OHV area near Oakridge. Maybe some of you local boys can show us around the hills there. I understand there is some excellent single track stuff there. If that's your neck of the woods.
    Thanks for the reply's.
    whoya
    by whoya » Fri Jan 26, 2007 5:44 pm
    JAWS wrote:I had the same issue after putting in the JD kit, etc. I opened the fuel screw more and it helped, but when I put in a richer pilot the issue went completely away. I had the 65 and went to a 70, but I live at 600' .
    #70 pilot jet? Wow! I'am having trouble with hanging idle with the stock pilot (45) I'm thinking about a 48. #70? really?
    01' WR250F mods and dollars added
    by Asmith » Fri Jan 26, 2007 5:49 pm
    No. he had a 45 and went to a 48.
    whoya
    by whoya » Sat Jan 27, 2007 12:11 am
    Thanks A.S. Wasn't sure what Jaws was Smokin...! I thought somthing wasn't quite right there. Must be a missprint....
    by JAWS » Sat Jan 27, 2007 6:45 am
    whoya wrote:Thanks A.S. Wasn't sure what Jaws was Smokin...! I thought somthing wasn't quite right there. Must be a missprint....
    Brain fart! :)
