BBR Springs Tech
  • crf150rider
    BBR Springs Tech
    by crf150rider » Mon Dec 20, 2004 7:59 pm
    OK, I am getting BBR Fork/Shock Springs 4 Christmas, and I have never fooled with suspension, so could n e one give me some tips on putting fork springs and shock springs on?
    Thanks
    2004 CRF150
    Sidewinder 428 Conversion Kit
    Twin Air Air Filter
    normb359
    Spring replacement
    by normb359 » Mon Dec 20, 2004 8:41 pm
    Here are the Basic steps.
    The rear is pretty simple. Remove the shock and then the top lock nut and then the spring. Reverse to install
    The front is not too hard. You will need the front wheel off the ground and all pressure off the suspension.
    Remove the handle bars
    Remove the fork caps. Keep track of the washers.
    Remove the springs
    Install new springs
    Check oil level
    Install washers and fork caps
    Install handle bars.
    Then go Ride, Easy for the first couple of minutes, make sure that you have no leaks and all of the air is out of the bottom of the forks. Bounce the front end a couple of times. Then go for it!!!
    "Be Safe and Ride It Like You Stole It"
    "If it is not fun- Find another hobby!!"
  • crf150rider
    by crf150rider » Mon Dec 20, 2004 10:22 pm
    How exactly to I check the oil level?
    What do you "make sure that you have no leaks and all of the air is out of the bottom of the forks."?
    Sorry for all the questions, I have never messed with suspension. Thanks.
    2004 CRF150
    Twin Air Air Filter
  • 150boy
    by 150boy » Tue Dec 21, 2004 12:23 pm
    take the dip stick out and make sure the oil is good and between the 2 lines on it but not sure on the leakes
  • 2004 hondaCRF150F
    by 2004 hondaCRF150F » Tue Dec 21, 2004 12:26 pm
    150boy wrote:take the dip stick out and make sure the oil is good and between the 2 lines on it but not sure on the leakes
    He wasnt talkin about the oil in the engine. He was talking about the oil in the forks. Ummm, you'll need a service manuel and it tells you how much it needs. Call your local dealer and see how much to add.
    2004 CRF150F #44(AMA #604) $2000 in mods. 95% of which are Powroll.
  • willflyforfood
    by willflyforfood » Tue Dec 21, 2004 4:00 pm
    crf150rider wrote:How exactly to I check the oil level?
    1-After changing the fork oil, slowly pump the fork pipe several times to stabilize the fork oil level.
    2-Compress the fork leg fully and measure the oil level from the top of the fork pipe. Should be 136 mm or 5.4 inches.
    dirty230
    by dirty230 » Tue Dec 21, 2004 4:28 pm
    Dude, you dont have to take the bars off,I just took the springs out of the 230 to add oil like 2 days ago.All i did was take the caps off,and made a mark on a dowel 3.9 inches and measured that way.Dont be confused I raised my oil level for factory springs,you should go with your perscribed oil level because of those new springs
    LIVE FAST,OR DIE SLOW
  • 2004 hondaCRF150F
    by 2004 hondaCRF150F » Tue Dec 21, 2004 7:59 pm
    dirty230 wrote:Dude, you dont have to take the bars off,I just took the springs out of the 230 to add oil like 2 days ago.All i did was take the caps off,and made a mark on a dowel 3.9 inches and measured that way.Dont be confused I raised my oil level for factory springs,you should go with your perscribed oil level because of those new springs
    We have to take the bars off cause we have 1 1/8" bars on the 2 150's that we have. So the bars get on the way.
