Rear BBR Spring?
  • Bags
    Rear BBR Spring?
    by Bags » Sun Dec 12, 2004 11:06 am
    How do U get the rear shock apart to replace the stock pring with the BBR spring?
    Bike is apart now anyone on-line?
    by crfsonly » Sun Dec 12, 2004 7:00 pm
    you have to compress the shock spring enough to remove the retaining collar. unless you have a spring compression tool you can use a rachet tie down strap (more than one as a safety precaution) to compress the spring far enough to remove the retaining collar.
    good luck...ken
  • Guest
    by Guest » Tue Dec 14, 2004 4:22 pm
    Thanks Ken,
    I will try this weekend
