Doubling jumps help
  • paintdirt16
    Doubling jumps help
    by paintdirt16 » Wed May 10, 2006 9:41 am
    Is there a certain way to double up on certain jumps?
    The track i ride at has a section with about 6 jumps with no landings. and they are about 10 feet apart. Should i practice doubling them?
    04 crf450
    by 04 crf450 » Thu May 11, 2006 7:40 am
    i would double or tripple them
    23 YZ250X
    23 FX450
    23 Tracer 9 GT
    2 990 ADV's
    15 CRF150F
    .......probably 12 others currently
    by crfsonly » Thu May 11, 2006 8:18 am
    double jumps pose an increased danger over a table top jump. if you come up short on a table top you can usually ride out of it. however, if you come up short on a double you can be seriously hurt. my recommendations is find a table top that is about the same distance and form and then run it until you feel EXTREMELY comfortable with it. then with the double start off slow and get a feel for the face of the first jump...continue to increase your speed until you are flat landing right in front of the landing jump. then find someone that lands this jump and follow them through the jump. keep the same speed they have over the jump. remember...it's less painful to slightly overshoot a jump than to come up short.
    good luck...ken
  • crf_rider.com
    by crf_rider.com » Tue May 16, 2006 6:03 pm
    just hold it wide open in third or fourth gear and you'll just jump it perfectly
    Crf250R
    run um hard run um stock
  • mitchell250R
    by mitchell250R » Mon Mar 19, 2007 10:40 pm
    wide open third or fourth? ya, if you want a broken neck
