suspension
  • puff336
    suspension
    by puff336 » Mon Apr 17, 2006 6:50 am
    Is there any way to adjust the stock suspension to be a little more forgiving? Not being a racer I'm not sure but my 50lb. 8 year old appears to be hitting pretty hard when he lands. Seems to hit hard and then takes a few seconds to recover. Thanks for any help.
    oldtimer
    by oldtimer » Mon Apr 17, 2006 12:19 pm
    There is no adjustment in the rear other than a stiffer spring. In the front you could add fork fluid to you max level. IF that did not help a heavier weigh fluid will help a bit more. Finally you would have to re spring the front as well.
    Is he on a 50 or a 70?
    06 CRF80
    04 CRF70
    88 CR250
    SSG_TOM
    by SSG_TOM » Thu Jun 08, 2006 9:43 pm
    Is your kid on a 50 or a 70? If he is on a 50, there is no fork oil. It's just springs and grease. I just redid my sons suspension. I went with applied racing heavy duty fork springs and an Ishock light rear shock. The light is rated for up to 150lbs. It is adjustable too. Good luck
    CRF250X (Boyesen quickshot APC, Fastway case guard, FMF Q2, guards, Maier hand guards)
    CRF50F sons
    Sportrax 400EX wifes (Pro taper S-E bars, pro armor nerf bars
    TRX250EX daughters
    200 Phoenix daughters
    90 Predator daughters
  • dirtdevil
    by dirtdevil » Wed Aug 23, 2006 7:54 pm
    If it's a 50 you're talking about, definitely go with the ishock, 1" longer fork tubes, and the 1" longer fork springs. Don't get the applied springs unless you want really stiff front suspension. I went with the two brothers racing fork springs. (Little softer)
    texas929
    by texas929 » Wed Oct 25, 2006 10:59 am
    To answer your question for a 50lb rider no they don't make anything. My step son hits hard too. The option is either to get a 2-stroke 50 or save your money and put him on a 65 soon. The second is our plan, just have him deal with it until then.
    '02 CRF450R (Me)
    '05 CRF230 (Wifes)
    '05 CRF50 (Step Sons)
