by JS450X » Fri Feb 02, 2007 11:45 pm
48 is pretty high already, you may have other issues that cause your problem. Heck, Team Honda is running 47 on rear and that's to go like 110 mph! It all depends on what type of riding you do,,,MotoX, Enduro, Trails? It it's Motox I recommend 14/48. Trails and Enduro more like 14/49-51. I agree with changing the front sprocket before the rear if you want to save money however be careful of clearance issues with your engine case, especially if your running O-ring chain. I run 14/49 on my 06 450-X and top out at about 85 (approx.) but still have a low enough 1st/2nd for tight technical stuff.
Try different combinations till you get what you want,,,good luck.
