cheap mods crf100f
    Flippincrf100f
    cheap mods crf100f
    by Flippincrf100f » Fri Apr 07, 2006 11:53 am
    anybody know about any way i can get some more power out of my 2005 crf100f without spending money or at least not a lot :D
  • branslide
    by branslide » Fri Apr 07, 2006 9:29 pm
    First take the spark arrester out if you can. Take the screen out of air box. turn your mixture screw right 1.5 turn and try that worked better on my 150. Drill half inch holes in air box if you want to butcher it. Depending on the terrain your riding. try that and have fun
    branslide
    06 450r supermoto
    04 450r dirttrack
    05 450 J&m frame
    03 150 crf
    Billys2006CRF100F
    by Billys2006CRF100F » Fri May 04, 2007 10:03 pm
    You can change the front sprocket to a 13 tooth for more torque or 15 tooth for more speed Me i am going to get a 15 tooth.
    Click on my GARAGE link to see pictures and modifications that I've done to my CRF100F.
    zak13
    by zak13 » Tue May 08, 2007 4:50 pm
    branslide wrote:First take the spark arrester out if you can. Take the screen out of air box. turn your mixture screw right 1.5 turn and try that worked better on my 150. Drill half inch holes in air box if you want to butcher it. Depending on the terrain your riding. try that and have fun
    what airbox screen
    i did the mixture screw and that just made it idle high or did i turn the wrong screw
    where do i drill my holes
  • .sinner
    by .sinner » Wed May 09, 2007 7:53 am
    You probably turned the idle screw
    Billys2006CRF100F
    by Billys2006CRF100F » Wed May 09, 2007 9:46 am
    Pull the seat, remove the snorkel, and drill a couple 1 inch holes in the top of the air box.
    zak13
    by zak13 » Wed May 09, 2007 1:18 pm
    so wheres the mixture screw
    Billys2006CRF100F
    by Billys2006CRF100F » Thu May 10, 2007 2:48 pm
    The fuel screw is on the bottom of the carb towards the front. Prior to 2005 it was a straight slot screw. 2005 and up has a "D" shaped screw. Dynojet sells a special tool to adjust the "D" shaped tool (DT-008) for $3.00. Check their website and call them directly to order it.
    zak13
    by zak13 » Sun May 13, 2007 4:57 am
    i looked all around my carb and there was only one screw and that was the idle screw
    zak13
    by zak13 » Sun May 13, 2007 7:17 pm
    what ever but wheres the airbox screen
    Billys2006CRF100F
    by Billys2006CRF100F » Sun May 13, 2007 10:26 pm
    It is underneath the carb. It's a straight slot or "D" shaped brass colored screw.
    zak13
    by zak13 » Mon May 14, 2007 1:27 pm
    ok wheres the screen
    zak13
    by zak13 » Mon May 14, 2007 1:32 pm
    i found the screw and it wont turn
    Billys2006CRF100F
    by Billys2006CRF100F » Mon May 14, 2007 8:11 pm
    If you are on right one, it will turn. If it's an older bike and hasn't been adjusted, than it might take some effort.
    zak13
    by zak13 » Tue May 15, 2007 4:10 pm
    wheres the screen
