Grip Installation
  • backbeat
    Grip Installation
    by backbeat » Fri Mar 10, 2006 8:53 am
    Great advice on removing grips, but what's the trick to installing them. Seems like the throttle side stops half way every time. :x Do you have to use grip glue, or is there another product that works? Is there something you can spray inside the grip that won't affect the glue?
    oldtimer
    by oldtimer » Fri Mar 10, 2006 9:16 am
    Grab your wife’s hair spray. Spray a little in the grip and on the tube and quickly jam it on. Never had one come loose.
    06 CRF80
    04 CRF70
    88 CR250
    BigOL3
    by BigOL3 » Sat Mar 18, 2006 3:52 am
    I know they have special adhesive now to use on gripes, but I have always used 3M weather strip adhesive. It is yellow, and normally called gorilla snot. :lol:
    Utah skidplate
    Unabiker red rad guards
    CRF's Only rear tugger
    CRF's Only FS
    JD jetting kit..170 main, red neddle, 4th pos
    Twin Air Power Flow kit w/Napalm mounting bolt
    Air box snorkle remvd... Exhaust baffle remvd
  • MauiMoto
    by MauiMoto » Mon Mar 20, 2006 1:03 am
    the renthal glue works really good makes em easy to put on and never come loose with renthal grips
    99
  • crfscrambler797
    by crfscrambler797 » Mon Apr 03, 2006 8:33 pm
    i use spray paint, it dries like glue and it makes it easy to install them, ive tried everything and thats the best ive found and i also put the tie wire on 3 to each side
  • chas
    Grip installation
    by chas » Wed May 03, 2006 8:00 am
    What ever glue you decide to use is fine I like Renthal but what I do works great try Puting 3 or 4 ty-wraps equally spaced aroud the grip inside and slide on then pull ties out with pliers use a good 1/4" tie. works great. You get a little glue on your ties and might have to throw them away but they are cheap compared to my labor at pushing them grips on without them.Teflon ties slideslideslide
    Ride Hard and Smart
    by 124 » Wed May 03, 2006 8:20 am
    Brakecleaner (non-chlorinated ofcourse). Melts the rubber and slides on "no problemo".
    I've found glue makes them a biiiaaatch to get em off.
    GhostX
    by GhostX » Wed Jul 19, 2006 4:03 pm
    Chas, I don't completely understand the zip ty method :-s :?:
    I have used the hair spray method with success. Just make sure the grips dry in sunlight for a few hours before riding, and they do come off with fair ease later. :D
    2006 CRF230F
    See the list of Mods in My Garage:
    http://www.crfsonly.com/forum/garage.ph ... le&CID=190
  • crf538kid
    by crf538kid » Thu Jul 27, 2006 6:28 pm
    flush the grip out with gasoline before putting it on the bars with rubber cement and it works great
  • mxrider1972
    by mxrider1972 » Fri Aug 11, 2006 8:02 am
    Start the grip on the bars then apply compressed air between the bar and grip while pushing the grip on. the compressed air expands the grip . never had one come loose yet.
  • motoracer710
    by motoracer710 » Sat Aug 19, 2006 8:49 am
    I use a fast drying clear spray paint. Spray a little on the bar ends (careful on the throttle side) and inside the grip. Let it dry and then spray a generous amount inside the grips and slid them on. Got this tip from MXA magazine. . .it's how they do all their test bikes and they learned it from a factory Yamaha mechanic. Never had a grip come loose. Getting them off is easy. Just use a utility knife with a new razor and carefully cut the grip down the center and peal the grip off like a banana.
  • RAZ
    by RAZ » Tue Aug 22, 2006 8:51 pm
    Plain and simple; use an air compressor with a blow tip, You blow air into the open side and it blows up while you pull it on. Just an old trick from many years ago.
    05 CRF 250X (what a ride!)
    05 KTM 300 MCX (also a gr8 ride!)
    96 DR650 Tricked Out
  • Dirtclod
    by Dirtclod » Fri Sep 01, 2006 11:03 pm
    I put my grips in the dryer for ten min or so they'll expand.Just before I pull them out I put the grip glue on the throttle side 1st depending on the grips sometimes I fire up the aircompresser and shoot air through the bars and the throddle side slides right on
  • Serp
    by Serp » Fri Jan 19, 2007 8:50 pm
    If you use hair spray, like I do, make sure you use one with an alchohol base (some types have slippery stuff in them).
    2004 CRF250X
    by JAWS » Fri Jan 19, 2007 11:03 pm
    Serp wrote:If you use hair spray, like I do, make sure you use one with an alchohol base (some types have slippery stuff in them).
    AquaNet used to be a good brand. Don't know if they even make that stuff anymore.
