Just another newbie with a hard to start 2007 CRF 250r . Bought last summer to get into mx and some singletrack, ran great in summer but started to get hard to start when hot , then as we came into a Canadian winter wouldn’t start at all. Checked valve clearances last night intake was in spec if not a tad loose, exhaust valves were at 0.009 maybe 0.010 inch but very tight fit ( spec is 0.011 inch ) am I right in thinking as the exhaust valves are steel they won’t wear as fast so can be shimmed a few times rather than a whole top end and head recut like the intakes ?
I also noticed what seems like excessive play in the auto decompression pin can anyone confirm if this is normal? I’m getting some side to side play but have been told that could be normal on older designed bikes , this motor has apparently 75 hrs . I do have a video but can’t upload it
Next thing is the timing didn’t quite line up between the cam markings and timing peep hole by the rear brake ( I checked clearances with the cam in the right place )
Thanks for any input .
