Hi, I just recently bought a 2013 CRF230F. I bought it from my brother and he was the original owner. I was confident in buying from him because I know he take care of his stuff. I didn’t realize I was buying a motorcycle that was meant for someone who is 80-100 lbs smaller than I am. I purchased my first upgrade for it today. I bought a BBR spring for the rear that’s supposed to be 30% stiffer then the stock one. I’m also eyeing some new springs for the forks. I’m looking at some from BBR and also Eibach. I want to see how the rear spring changes the ride before moving on. I was also eyeing a new shock/spring combo with an external reservoir, but it was a little over $600 more than the spring I bought so I decided to go the cheaper route first. I will be riding mostly dirt roads and trails with various levels of road quality. I also might putt around or drive it like I stole it or somewhere in between those two points.
My next purchase for it should be a clymer manual. I’m not sure if I’ll do new springs in the forks or send them off this winter for someone else to work their magic on them. I’m here now hoping to get some input from people more knowledgeable about this than I am that can help me with some info so I can decide which direction to go in.
I also plan to rejet the carb, remove the snorkel from the air box and a new exhaust system or at least remove the baffle from the stock one. I then want to put a 14t sprocket on the front and a 48t in the rear.
Any positive input will be appreciated.
