Project Bike Modication List
    by crfsonly » Wed Feb 22, 2006 7:51 pm
    Here's the much anticipated modification list. This will be an incredible 450x!
    Yet to be determined are the following. Please clarify your suggestions for the final list on these items:
    1. Which Exhaust? Yosh Carbon, E2, Stock, Others
    2. Which CAM? Stoc, Stage 1, Stage 2, Other?
    3. Fluidyne Radiators? Stay with stock or go with Fluidyne (I'm not sure of the compatibility with radiator guards)
    4. Which Bar Bend? Keep in mind we are targeting a 180lbs rider of average height.
    5. Which Pegs??? IMS F3 Pivot, PC-Ti, White Brothers Tri-Pro Ti?
    6. Final drive gearing?
    Great job everyone! We are almost to the fun part...building this monster!
    Ken
    CRF's Only Project Bike
    Bike: CRF450X
    Type of Build: Offroad/Trail
    Performance
    JD Jetting Kit
    Boyesen Quickshot
    Airbox Mods
    Twin Air PowerFlow Kit
    ??? Exhaust Yosh Carbon, E2, Others
    ??? CAM
    Napalm Filter bolt
    Zip Ty Hot Start Nut
    CRF's Only Fuel Screw
    Rekluse z-Start w/ Perch Adjuster
    Applied Vent Kit or Rob's Vent
    Applied Smog
    Five-10 Case Saver
    PC Thermstrips
    ??? Fluidyne Radiators
    Zip Ty Magnetic Drain Bolt
    Suspension
    Forks and Shock Valved and Spings
    RG3 Link
    Controls
    Pro Tapers
    ??? Bend: ???
    BRP Triple Clamp
    BRP SUB Mount
    Scotts Stabilizer
    Hammerhead Shifter
    ??? Pegs??? IMS F3 Pivot
    PMB Kickstand
    Cycra Pro-Bend CRFX Handguards Acerbis Rally Pro
    Works Elite Perch
    ASV Levers
    ASV Perch Clamps
    Spider Grips Renthal Grips
    Joker Throttle
    Braking
    Wave Rotors
    Stainless lines
    Fastway Cable Clip
    Wheels/Tires
    Excel Rims
    Talon Hubs
    Dunlop 756 Tires
    T.M. Designs Slide-n-glide
    Protection
    WC Skid Plate
    WC Master Cylinder Guard
    WC Rear Brake Guard
    Scotts Rear Disc Protector
    Flatland or Unabiker Radiator Guards
    Brake Snake
    Reklust Clutch Cover
    Drivetrain
    D.I.D 520VT Chain
    ??? Sprockets - Gearing?
    Zip-Ty Axle Blocks
    Electronics
    Trail Tech Lynx and Protector or Acewell
    Vortex or Tokyo Mods Ignition
    Rewound stator
    Baja Designs HID Headlight
    Hour Meter
    Rear Brake Light
    Appearance
    UFO White Plastics
    Custom CRF's Only Graphics
    Wheels: Hubs-> RED, Rims-> Silver
    Hoses: Red
    WC Engine Plugs
    WC brake reservoir covers
    Misc
    IMS 3.2 G Tank - Black
    RottenRob
    by RottenRob » Wed Feb 22, 2006 10:11 pm
    4. Pro Taper Kevin Windham bend
    6. 13/49
    As for 1. I have the Yosh and it is a great pipe for weight savings, build and looks but I don't think it provides any HP gain, maybe the E2 would be better? Who has one and did they notice a power increase?
    Life's tough, but it is even tougher when you're stupid.
  • Showtime
    by Showtime » Thu Feb 23, 2006 2:44 am
    1. E2 exhaust
    2. have no clue ;-)
    3. Stock is fine with me
    4. Kevin Windham
    5. White Brothers Ti
    6. I will leave this choice up to you experts. ;-)
    I was just thinking, who is providing their stock 450x for this transition???? Hmmmm, hey Ken, would it happen to be your bike were all fixin up??? ehehehe
    Anyway, here's a thought. Get the sponsors on this deal to pony up the stuff so we could do a fund raising raffle for JAMES MARSHALL (Kid that broke his spine just a short time ago) when this bike is all done and after the testing by Dirt Rider. 10 bucks a ticket enters you into the drawing to win the bike. Might cut into some people's bling budget, but just an idea. ;-)
    Cliff
    Rekluse w/perch adj
    BRP Triple Clamps 22m
    JD Kit
    Open Air Box
    Boysen Quickshot
    Acewell Speedometer
    TourTech GPS mount
    Scotts rear shark fin
    Works Connection skid plate, radiator braces.
    Roady
    by Roady » Thu Feb 23, 2006 6:08 am
    I also run and like the Pro Tapers-Windham bend. Only other comment I have is the IMS tank, I definitely prefer the see through over the black having had both.
    This bike will be killer!
    It is a good day to ride
    04 crf450
    by 04 crf450 » Thu Feb 23, 2006 6:16 am
    tokyo mods ignition :D
    ken, have you seen those fasst co flexx bars
    23 YZ250X
    23 FX450
    23 Tracer 9 GT
    2 990 ADV's
    15 CRF150F
    .......probably 12 others currently
  • JoePezz
    by JoePezz » Thu Feb 23, 2006 7:02 am
    1. Which Exhaust? White Brothers Carbon
    2. Which CAM? Stock.
    3. Fluidyne Radiators? Stock, so we can use Rooster Radiator guards. No one wants broken Radiators.
    4. Which Bar Bend?CR Mid or Windham (Protapers)
    5. Which Pegs??? White Brothers.
    6. Final drive gearing? Go with whatever you feel is best.
    Ted
    by Ted » Thu Feb 23, 2006 7:24 am
    1. Yosh carbon (Weight savings)
    2. Stock cam (This bike will rip with the other mods and jetting)
    3. Fluidyne if compatible with rad guards (if compatible use stock protection is a must)
    3. I use CR High bend on my 450R
    4. IMS pivot
    5. Not sure of X gearing but I would want it low enough for tight rough stuff
    :D :D :D :D :D :D :D :D :D :D :D :D :D :D
    CRF450R '05
    IMS tank
    GPR stabilizer
    Longhorn bars
    Devol skidplate
    Pro Moto Billet S/A
    Ride it like you stole it!!!
    If your not wrecking your not riding hard enough!
  • KaBooM
    by KaBooM » Thu Feb 23, 2006 8:10 am
    Ken, Synergy Seals will donate a set of fork seals to the project.
    Thanks, Rob
    www.synergyseals.com
    To be BOLD is BOLD, but to be confident is certain!
    Ride With Confidence Again!
  • Socal X Rider
    by Socal X Rider » Thu Feb 23, 2006 9:45 am
    1. White Bros carbon (only if it has a spark arrestor - forgot if it did or not)
    Yosh carbon or Pro Circuit Titanium (I know these have spark arrestors)
    Final gearing is an individual taste. Is this bike going to be ridden more in the desert or tight trails or a combo of both. Go three down on the rear (48t).
    Combos 13/48 or 14/49
    02 RM250
    00 ZR-7
    by Ernie Pezz » Thu Feb 23, 2006 11:33 am
    1. E2
    2. Stage 2
    3. Fluidyne if they fit w/rad guards
    4. Keep bend height for average height rider
    5. White Bros. Tri-Pro Ti
    6. Gearing would depend on the terrain it was going to be tested in.
    Ernie
    PGer555
    by PGer555 » Thu Feb 23, 2006 12:10 pm
    definatly the E2 exhaust...
    uniped
    by uniped » Thu Feb 23, 2006 3:56 pm
    Exhuast >Yosh carbon (I preffer Yoshimura)
    Cam>Stage 1(low cost big gains)
    Radiator>Fluidyne(again provided they are functional with guards)
    Bar Bend>Woods High (Narrow for trails and bout 3/4" height increase)
    Foot pegs>Fastway (not listed but adjustable)
    Final drive>Suggestions should be from a 450X rider)
    Thanks Ken for hold'n in there through the argumentative stage. Look forwar to some pics!
    ________
    THINKMILL
    by Smash » Fri Feb 24, 2006 2:18 am
    1. Which Exhaust? www.mrdracing.com
    2. Which CAM? Stage 2, let's give this bike some wings.
    3. Fluidyne Radiators? Fluidyne looks way trick and cools well. If your ridding in socal it's nice to have.
    4. Which Bar Bend? Carmichael bend, Honda can't be wrong.
    5. Which Pegs??? Fastaway
    6. Final drive gearing? No Opinion.
  • Dust Devil
    by Dust Devil » Fri Feb 24, 2006 9:23 am
    Bike: CRF450X
    Performance
    JD Jetting Kit
    Boyesen Quickshot
    Airbox Mods
    E2, Quiet, spark arrested, has power gain
    No need for a cam
    Napalm Filter bolt
    Zip Ty Hot Start Nut (not that important)
    Rekluse z-Start w/ Perch Adjuster (not needed)
    Applied Smog (they might frown on this)
    Fastway case saver Or Summers racing
    PC Thermstrips (not needed)
    ??? Fluidyne Radiators (not needed)
    Zip Ty Magnetic Drain Bolt (not needed)
    Suspension
    Forks and Shock Valved and Spings (precision concepts)
    RG3 Link (not needed)
    Controls
    Pro Tapers
    ??? Bend: ??? (windham nice rise, very little sweep)
    BRP Triple Clamp
    BRP SUB Mount
    Scotts Stabilizer
    Hammerhead Shifter (not needed unless you have 13+ size feet)
    ??? Pegs??? IMS F3 Pivot (not needed)
    PMB Kickstand (whats wrong with stock?)
    Cycra or Enduro Engineering (I have seen where Dirt rider prefers EE)
    Works Elite Perch (Why?)
    ASV Levers (why?)
    ASV Perch Clamps (why?)
    Spider Grips
    Joker Throttle (why?)
    Braking (stock brakes are plenty adequate)
    Wave Rotors
    Stainless lines
    Fastway Cable Clip
    Wheels/Tires
    Excel Rims
    Talon Hubs
    For offroad (desert) the dunlop 739F or Maxxis desert IT would be a way better choice
    moose or maxxis HD tubes w/True Goo
    Protection
    WC Skid Plate Or Flatland
    WC Rear Brake Guard
    Scotts Rear Disc Protector or EE
    Flatland or Unabiker Radiator Guards (Flatland are way better)
    Brake Snake
    Rekluse Clutch Cover (Rekluse is not needed)
    Drivetrain
    D.I.D 520VT Chain
    Ironman Sprockets - Gearing? 13/49 or stock
    Zip-Ty Axle Blocks
    Electronics
    Vortex or Tokyo Mods Ignition (not needed)
    Rewound stator
    Hour Meter
    Rear Brake Light (not needed)
    Appearance
    UFO White Plastics (not needed)
    Wheels: silver
    Hoses: stock
    WC Engine Plugs (lame)
    WC brake reservoir covers (lame)
    Misc
    I suppose if you wanted to showcase every product you sell go ahead, but I dont think thats what DR is looking for.
    Also might want to consider a fender bag with a front tube,Co2 kit,irons,3 way t-handle and 7 way screwdriver.
    Ted
    by Ted » Fri Feb 24, 2006 10:17 am
    Dust Devil wrote:Also might want to consider a fender bag with a front tube,Co2 kit,irons,3 way t-handle and 7 way screwdriver.
    :idea: Great idea!! I think we all overlooked that.
    CRF450R '05
    IMS tank
    GPR stabilizer
    Longhorn bars
    Devol skidplate
    Pro Moto Billet S/A
