R OR X?
  • Boubou
    R OR X?
    by Boubou » Fri Sep 10, 2021 9:45 am
    Just bought 2006 crf450 but not sure if it is a r or a x. How could i check? Thank you. :-k
    Re: R OR X?
    by JimDirt » Fri Sep 10, 2021 10:11 am
    The bike "should" have a sticker on the frame spar that says (for example) 2006 CRF450R or CRF450X
    It would look like this and should be present on all years and models , it will either be on the left or right frame spar
    If for some reason that is missing or damaged it can also be identified with the vin # , located on the right side of the headstock , for a R the vin # would have PE05 as the 4th thru 7th digit , as well as the 10th digit would be a 6 for the year , indicating a 06 450R
    For a X it would be PE06 along with a 6 as the 10th (year) digit ..... Indicating a 06 450X
    Hope that helps .... ;)
  • Boubou
    Re: R OR X?
    by Boubou » Fri Sep 10, 2021 10:29 am
    Thank you!!
    Re: R OR X?
    by JimDirt » Fri Sep 10, 2021 10:53 am
    No problem ... Glad to help ;)
