CRF250R 2008 decompressor
    runchux
    by runchux » Sat Aug 28, 2021 11:13 am
    Hi!
    Long time ago I bought CRF250R 2008 In a box, competely trashed, with exhaust valve broken and destroyed head.
    After 2 years of thinking what to do with it I started to completely rebuild it.
    Engine is almost ready, but I have 2 consernes regarding it, and hope that this is the place where someone could clarify them for me.
    1) 2008 CRF250R is single cam engine, with marks on cam sprocket with 180 degrees between them. I managed to install cam with all marks being where they should be, Piston in TDC and cam marks in line with head. But after that I got worried that in theory you can install cam wrong way, (by turning it 180'degrees). After looking through manuals, I think I installed it correctly. Intake cam lobes are facing intake side. (as shown in manuals). But when I turn engine with kickstarter, after TDC first valves that start to open are exhaust valves. In some forums I found that after TDC intake valves should open... Which one is correct?
    2) I didnt disassemble decompressor, but installed as it was when I received it. But ... When I turn engine slowly as soon as decompressor shaft meets exhaust cam arm, it gets pressed to one side, and as soon as it passes it, it jumps back to middle with uncomfortable clanking sound. When you manually turn weight up on end of cam, that decompressor shaft turns and passes arm smoothly without any sounds. Am I just worrying too much, or its something wrong with it ?
    3) I think I shimmed my gearbox correctly, with all washers just like in spare part book, but still from countershaft or mainshaft (dont know which is which) (shaft where small sprocket mounts) I still get like ~0.7mm movement inside-outside, is it something wrong with it and I should brake engine open again, or it is normal with CRF's ?
    Big thanks on any answers in advance.
    //When in doubt apply more throttle//
  • Leardriver
    Re: CRF250R 2008 decompressor
    by Leardriver » Sun Aug 29, 2021 12:41 am
    Welcome! A picture of the cam installed would be a big help.
    Are you worried that you may have the cam 180 degrees out of time? The CRF engine is a wasted spark ignition system, which means that the spark plug fires every time that the piston come up. Therefore, you establish TDC on the compression stroke by installing the cam.
    Are the cam lobes facing up and angled back towards the rear of the bike?
    runchux
    by runchux » Sun Aug 29, 2021 3:30 am
    Hi!
    Yes the cam lobes are facing back of the bike, but intake lobes are more paralel with head than upwards.
    Pictures
    gti 2016 0 60
    One one picture I turned engine a bit, so you can see decompressor pin being pushed to one side.
    by Aussiecrf230 » Sun Aug 29, 2021 2:56 pm
    If the inlet lobes are about the 2 o'clock position then that's correct.
