260mm Caliper Bracket for '15 250R fork swap to 09 450 KYB
  • iahonda
    by iahonda » Tue Aug 24, 2021 10:57 am
    Hi, I'm swapping a set of 09 crf450r forks to a 15 crf250r to get rid of the air fork. Does anyone know where I can find a caliper bracket that will work for these forks and the stock 260mm rotor?
  • iahonda
    Re: 260mm Caliper Bracket for '15 250R fork swap to 09 450 KYB
    by iahonda » Tue Aug 24, 2021 3:56 pm
    After a lot of research it looks like the Braking POW78 is the 260mm bracket for an 09 CRF450R, for future reference in case anyone else doing the same comes across this. It's confusing because most sites list it as 270mm but there is a footnote (on some sites) which explains that for some models it is used for 260mm rotors. Not sure who came up with the brand "Braking" or who makes these but it's so generic it's hard to find information on it.
    The only alternative I could find in stock is the moto-stuff bracket but it's $120 vs $50 for the braking part.
    by JimDirt » Tue Aug 24, 2021 5:39 pm
    Braking has been around for some time , they are quality stuff .... but yea swaps are always sketchy on info as to what interchanges with what , because of slight differences that each year , or size(250/450) have , I was just going to suggest to get a mount for the 09 , but I guess you figured that out already , so you should be good to go =DD ..... thanks for the update ;)
