Will a 2019 450 motard kit fit on a 2019 250L?
  • nathan207
    by nathan207 » Wed Jul 21, 2021 11:16 pm
    Am I able to put a 2019 450 motard kit on a 2019 250L?
    Has oversize disc and after market rear, fits 2017-2019 450R. Got adaptor for 2017 front brake caliber and comes with front and rear sprocket 15 and 45.
    Many thanks
    Re: Will a 2019 450 motard kit fit on a 2019 250L?
    by JimDirt » Fri Jul 23, 2021 7:42 am
    About the only way you are going to know is to test fit the wheels .... I am thinking the front wheel will work , but the rear might be a issue , but I am not sure , as the width on the hub at the sprocket is different on the 17-21 R/RX , so the rear sprocket is offset around 3.75mm on the R from the older gen bikes , not sure if they carried that change in setup over to the L .... but that is where I think you would have a issue , the only other possible issue may be the axel diameter in the front ... especially being a 250 , the axel and fork lugs may be different/smaller .... so , honestly the only way to find out , is to test fit .... maybe if you have a friend that has a late model R or RX (17-21) maybe he would let you do a test fit , either by placing your wheels on his bike , or his wheels on yours ... As I am not aware of anyone who has tried this setup ...
