CRF 230F '14 - Carb bowl leak
  • nachtmsk
    by nachtmsk » Thu Jun 17, 2021 5:22 am
    Hi,
    I have a CRF 230F, 2014.
    I took off the bowl of the card cleaned it and replaced the main jet and pilot jet with stock jets. Ethanol gummed up the jets and they needed to be replaced.
    However, when I put it back together and turned on the fuel, after a few mins, fuel started seeping through the seam where the bowl connects to the main body of the carb on the intake manifold side. Fuel leak was not an issue before.
    I took it off again and checked the gasket and made sure the screws were tight, but it's still seeping.
    So I look around YouTube and it seems to be leaning to the float valve - does that sound reasonable. What else could it be?
    Also, if I replace the bowl gasket, the current one looked like it had some type of sealant to keep it in place. Do I use a sealant on the new gasket?
    Here is a video to show the leak a few mins after I let fuel into the carb.
    Thanks
    Mike
    Re: CRF 230F '14 - Carb bowl leak
    by Aussiecrf230 » Thu Jun 17, 2021 3:07 pm
    If it is leaking past the float bowl seal then the seal replacement should fix the problem. Normally there would be no sealant on seal.
    Maybe put a little grease on seal before you fit up the bowl.
    If the needle and seat are not sealing fuel will leak out the overflow tubing taking it underneath the bike.
  • nachtmsk
    by nachtmsk » Fri Jun 18, 2021 9:15 am
    Thanks Ray. I really appreciate the response. Ordered a gasket.
    Mike
    by Aussiecrf230 » Sat Jun 19, 2021 2:13 am
    Make sure there is no damage to the mating surfaces.
  • nachtmsk
    by nachtmsk » Fri Jul 16, 2021 8:02 am
    Quick update.
    I installed the new gasket and used some grease to keep in in place. That was the trick to make this work.
    No more leak and bike starts fine.
    Thanks
    Mike
    by Aussiecrf230 » Fri Jul 16, 2021 3:23 pm
    Glad to hear and thanks for the update Mike.
