Spark but dont start crf450-19
  • Lillnaisarn
    by Lillnaisarn » Thu Jun 17, 2021 2:07 am
    I have got a crf450r-19 that im not sure what's the issue are.
    I have so far:
    - Changed the sparkplug
    - Dissconnected kill switch
    - spray start fluid and dip sparkplug in fuel
    The bike dont want to fire up at all .
    Re: Spark but dont start crf450-19
    by JimDirt » Thu Jun 17, 2021 9:02 am
    Is the MIL light blinking when starting ?? .... Also , when you dipped the plug in gas , it did not even try to start ?? , not even a pop ??
    Can you hear the fuel pump when cranking ?? , and have you removed the gas cap vent line to make sure it is not clogged ?? , or removed the gas cap to see if you hear any air ?? , like when you open a fresh jar of pickles and it pops , this would indicate a clogged vent line or gas cap , if it is not venting it will vapor lock the system
    Also , have you checked the valves ?? , if the valves have closed up , that will not allow it to run , and how many hours are on it ??
    Usually if it is a fuel issue , the gas dipped plug will usually do something , so if it did not , that might mean it is valve related
    One last thing , did you recently wash the bike and try to start it afterwards and that is when this happened ?? , if so , you need to unplug every exposed connector and blow it out with air and reconnect and try again . water may be shorting the system out (a dirt bike you cant get wet , go figure , but it happens)
