Correct shim kit for 2020 CRF250L
  • newbtocfr
    by newbtocfr » Mon Jun 07, 2021 7:18 am
    The manual does not list the actual diameter of the shims needed :? . Only 1000 miles so unlikely that I need it but would like to buy one in case I do.
    Re: Correct shim kit for 2020 CRF250L
    by JimDirt » Mon Jun 07, 2021 7:19 pm
    Your bike should take the 7.48mm shims .... ;) ... Just get the HotCams Shim Kit , it will have all the shim sizes you will ever need for it
    And most likely it will be a while till you need a adjustment , personally I would not even worry about buying the kit till you notice them change , then get it , then also prepare to eventually do a valve job , as once they start moving , they will eventually zero out , then , once you get to the smallest shim in the kit , there is no adjustment left and you will then need a valve job ..... guesstimation , it should hopefully be a few years .... your mileage may vary 8-[
  • newbtocfr
    by newbtocfr » Wed Jun 09, 2021 6:34 am
    Thank you. I finished it yesterday and it was well within the specs. I need to buy a feeler gauge that has more granular blades in the 0.16 and 0.27 range though.
    by JimDirt » Wed Jun 09, 2021 5:45 pm
    You want feeler gauges like these , this is what I use
    https://www.ebay.com/itm/184332092755?e ... SwWPtemhba
