Stripping an X model down for GNCC style racing.
  • mick730
    by mick730 » Fri Feb 10, 2006 7:05 pm
    I am taking an X this year, and stripping it down closer to the R spec, for off road /GNCC racing, rather than building up an R to an R/X hybrid. I am removing most of the enduro hardware, the battery, kickstand, the headlight, for weight and reliability issues.
    For instance, are there any issues bolting on a R front numberplate?
    Anyone with experience with this general process that would like to shed some light would be appreciated...
    by Old Dude » Sat Feb 11, 2006 10:06 am
    mick730
    The OEM R plate will not interchange with the X headlight/plate (mounting isssues) If you don't want to change the triple clamps Cycra makes a front plate that will work. Available from right here at crfsonly. Several of the members have done this and are very pleased with the result. FYI R rear fender fits; left side panel does not
  • mick730
    Cycra plate sounds like the way to go.
    by mick730 » Sat Feb 11, 2006 10:25 am
    Thanks...I think the Cycra plate will be the way to go. CRF's only will get my business.
    I plan on weighing all the parts, and seeing how much I can get off the bike by just removing the extra items added to the X. Great bike stock, real interested to see how this plays out once I put it on a diet.
    by Old Dude » Sat Feb 11, 2006 11:33 am
    Check this out. This is what mulisha498 did. You might get some weight saving tips here.
    http://crfsonly.com/forum/viewtopic.php ... sc&start=0
    by crfsonly » Sat Feb 11, 2006 12:02 pm
    i use the cycra plate on my X and it works great...i keep extra zip ties in my tool box so i can take it off and put it back on. it takes three zip ties. there are two types of these number plates...full and half vented. the half vented will help with air flow to the radiators.
    the starter is pretty heavy but is not easily removed.
    after market triple clamps weight less and are more rigid making for more percise steering.
    talon hubs and excel rims are weigh less than stock wheelsets. these are expensive but not only will you shave weight but you'll also gain strength. plus unsprung weight savings is worth double the weight savings.
    aftermarket plastics also weigh less.
    more exotic things are a titanium subframe (i'm working with a company to produce one for the X as well as an aluminum version), titanium footpegs, titanium bolts and nuts, etc.
  • itsgrady
    by itsgrady » Mon Apr 07, 2008 5:16 pm
    How bout an aftermarket exhaust, chain, and titanium sprockets?
    2009 KX100
    *SST Expansion Chamber
    *Q Silencer
    *Boyesen Rad Valve
    *Acerbis Plastics
    *Monster Energy Graphics Kit
    *2.4 Gallon IMS Tank
    *Kevlar Renthal Grips
    *Tag Bars
    *Boyesen Rad Valve
  • CalledFollower
    by CalledFollower » Sun May 17, 2009 7:23 pm
    I know its not really relevant, but I seen an article in a bike mag a while back where they put a 250R on a diet, and got it down below 200 pounds. It was wild what all they did.
