Honda CRF 250x rear suspension assembly for heavy riders?
  • David WC Jones
    by David WC Jones » Wed May 26, 2021 10:26 pm
    Doesn’t anyone make a rear spring and shock assembly for riders between 220lbs and 250lbs?
    Re: Honda CRF 250x rear suspension assembly for heavy riders?
    by JimDirt » Thu May 27, 2021 4:23 pm
    Pretty much every aftermarket suspension company does , Race Tech , Pro Circuit , Ebach , Progressive Suspension , ALL should have a spring set to fit your size , it is a very common size to be over 200 , and the springs are the same 250 or 450 , so they should be plentiful , you should be somewhere around a 0.47 (stock for a 450) and 6.2 for the rear , or a rate higher on each if you are closer to 250 , which should be available anywhere , the rates I mentioned is for someone around 235/240 give or take since that is kind of in the middle of your listed weights
