Hi guys new to the board. Pretty good with carbs....usually. My buddy’s CRF150F 2007 wouldn’t idle off of choke so I brought it home took the carb apart and cleaned it as it needed a little love. Bought an All Balls racing rebuild kit and replaced all orings and jets with stock size (was already stock)
Put it back together and it idles extremely high. Will not start or run with choke ON only with choke off. Has stock needle with 2 positions clip is in lower position. Has a 40 pilot jet with a 95 main jet. The fuel screw had the “d” style and has been replaced with a slotted style and is 2 turns out. When idling high the idle screw is 2.5 turns out and if I back it out more the idle does not change however if I turn it in the idle speed climbs even more. I have moved the fuel screw from anywhere from 1.5 - 3 turns out and it has no affect on idle as I would think it shouldn’t due to stock jetting. Please tell me what I am missing?
I sprayed WD 40 as I didn’t have carb cleaner on the boot and vac lines will it was running to see if it changed anything and it didn’t. Appears no air leaks on either side of carb. The accelerator pump line routing is a little funky looking. Perhaps I have lines crossed up. As it was running I tried unhooking some to see if anything would change in idle speed and nothing. I have jetted and setup many carbs 2 stroke and 4 but am overlooking something obviously. Please tell me what I am missing. The needle jet holder is a little mushroomed on the end so I am going to Honda tomorrow to get one of those and a new idle screw set in case something is off with that as well.
Pleas help me out on what I might be missing. Does anyone have a routing diagram for the lines from the accelerator pump to the carb body? Appreciate any and all input here.
If I can get this idle problem solved I would love to uncork this thing with a bigger pilot, main, no baffle and open the air box but seeing as how it ran good stock before and now idles crazy high I just want to get it running stock again before tweaking anything else.
Thanks so much
