What would you do???
  • BigRed250
    by BigRed250 » Fri Mar 05, 2021 12:22 pm
    2013 Honda CRF250L with approx 800 miles on it.
    Going through the process of upgrading the suspension with the full Ohlins rear shock with piggy back and front spring kit/fork caps. My question is would you replace the seals at the same time you are doing the upgrade, even though my bike shows no sign of leaking seals and I have had seal saver neoprene covers on it since I starting riding off road with it. Replace or if it aint broke don't fix?
    Thank you
    Re: What would you do???
    by JimDirt » Fri Mar 05, 2021 12:37 pm
    With that little time on it and no signs of leaking , I would not worry about it at this point ..... if you do seasonal maintenance , like servicing the forks , etc. , then you might want to do it , but again , if all looks good , and you do not see signs of leaking , then don't worry about it .... as long as you keep the sand/mud from building up.... then drying , which is what usually kills seals , as the sand/mud will get almost rock hard when it dries , then when the suspension travel goes past that point of the clump , is when the seal will get damaged and leak .... I usually physically wipe my tubes down after every ride , I don't even allow water spots to stay after washing the bike , as they can have Calcium in it ,and that will harden and compromise the surface of the fork tube and then cause the seals to get cut , and then it will leak ,......., but with no leaks and keeping the forks clean , you should be fine for a couple seasons or so . so go ahead and install the cartridges and enjoy the improved ride ... ;)
  • BigRed250
    by BigRed250 » Fri Mar 05, 2021 12:53 pm
    That's kind of what I was thinking as well. After doing some research I am going to change my post ride maintenance to include a quick clean of the seals with a seal saver type of contraption to hopefully catch any dirt before it becomes an issue. Thank you for your response. Looking forward to the new suspension for sure!
    by JimDirt » Fri Mar 05, 2021 3:07 pm
    What you can do is when you ride in iffy conditions ,when you are done just take a putty knife or a thin wide fat blade screwdriver , and pop the Dust Seal (the seal you actually see on the forks) and pull it down , and if you have a compressor , then blow the air at the seal area to blow out any dirt/sand/mud that might have got by ... do not put direct air pressure on the fork seal itself , as you might blow the oil out a bit . just a quick blowing off will do , then wipe down the fork tube , then slide the dust seal back on and push it into place , if you don't have a fork seal driver , you can make due with a large Crescent Wrench and open it up to the size of the seal (just slightly larger than the for tube) , then just tap it into place to seat it into the tube using a hammer on the handle of the Crescent as you are holding it (tap close to the tube to get a solid and square hit on the seal) , and you should be good to go
