EFI not turning on
  • mhmdhn
    EFI not turning on
    by mhmdhn » Fri Mar 05, 2021 12:41 am
    Hello guys,
    I have a CRF250L 2015 model. Suddenly the EFI is not turning on at all. I tried turning off and on the kill switch several times but no luck. Battery and fuses are all good. Not sure what the cause though. I washed the bike like 4 days ago and had the same problem but it worked when I turned off and on the kill switch. But this time nothing works. Please advice me on this. Thank youu
    Re: EFI not turning on
    by JimDirt » Fri Mar 05, 2021 9:25 am
    Unfortunately , the issue is because you washed the bike and got the switch wet ....... The kill switch gets moisture inside it , if you try to start the bike with the moisture in it , it will usually fry the switch .... I am hoping that eventually Honda goes back to the old style kill button , as this new electronic one is not sealed tight enough to allow it getting wet .....
    You might end up having to replace the switch ,,, then the next time you wash it , do what I do with my 2020 450R , put a gallon size ziploc bag over the bar end covering the switch and secure it in place with a garbage bag tie , then wash your bike , then remove the bag ..... This is a common issue with the new gen bikes , and I wish Honda would come up with a better switch design , as this happens way too often .... :(
  • mhmdhn
    by mhmdhn » Fri Mar 05, 2021 6:03 pm
    Hello thanks for the reply. Im not sure if that's the case. Coz it was working fine for few days after the wash. And this has happened once before and the mechanic fixed it, he said he did a reset and all good. But il not sure whats actually causing the problem 😪
    by JimDirt » Fri Mar 05, 2021 9:02 pm
    What did he "reset" ????? :-k 8-[
  • mhmdhn
    by mhmdhn » Sat Mar 06, 2021 8:51 am
    Yeah thats what im not sure about too :| ...btw today in the morning the fuel pump started to work again suddenly and everything was good until tonyt when I turned on the ignition guess what same problem again. Im not sure what to do though...tired of this.....planning to give it to the mechanic again
    by JimDirt » Sat Mar 06, 2021 5:08 pm
    It still might be the kill switch , they have a lot to do with the bike running correctly
  • mhmdhn
    by mhmdhn » Sat Mar 06, 2021 6:18 pm
    Ahhh I should check it and will update it here, thank you very much :D
