by JimDirt » Wed Jan 20, 2021 10:02 am
Hmmmm . OK try this ... Take a small hose (vacuum hose , gas hose etc. ) and dip it in some gas and put your thumb over the top , put it in the spark plug hole and release your thumb , put the plug back in (no need to install the tank) and spark plug boot , and try to start it (try it with the choke on , then off) , see if it attempts to start , this will either confirm or eliminate a fuel issue , you can also unplug (in another test) the TPS , as the bike will run without it hooked up , this should either confirm or exclude the TPS , but the bike should run with it hooked or unhooked and start right up
The compression sounds off a bit , it could be that you are getting blow by thru the rings ... this would drop the compression and cause hard starting , if the decompressor is acting up , it would most likely cause higher than wanted compression , so it sounds like it is working , though it could be sticking , maybe check the plunger , or pull the unit and make sure the pin is good and the shaft is not broken and that everything is free ( the owners manual should have a test for the decompressor) , when you are checking the compression are you kicking it hard like you would when you start it ?? , and are you holding the throttle wide open ?? , this is key for getting a correct reading ..
It does sound like most things are where they should be , though not everything ..... so eliminate each item ..... also it is possible that the stator could be acting up , have you tried bump starting ?? , this might give enough umph to get it to start , and that might lead you to the source of the starting issue ..... But I would go thru each item in the electrical system to eliminate it , and also , if it does start with the hose in the plug hole test I mentioned , then also check to make sure the gas cap vent is not clogged (if it is stock the hose can get mud dauber wasps in it , they build a cocoon and the tank wont vent and it causes a vapor lock , also the aftermarket ones , sometimes have a issue (mainly because of ethanol) with buildup and the checkball sticks and it won't vent ,, WD-40 or carb cleaner will free it up and just shake it till it moves freely ...... although a blocked vent usually is noticeable after you are riding and the bike starts to bog down , then you pull the vent line and the bike comes to life again or even though you mentioned the carb being rebuilt , maybe the float level is too low and not feeding the jets , as it only takes a small amount of fuel to get to the AP Pump , but it takes a higher level to allow the main and pilot jets to suck up the fuel
Basically I think if the hose does not make it start right up , then either you have a low compression issue (you heard air in the case which indicates ring blow by) , or electrical , most likely the stator ...
