Rally stock spring rates
  • Rally18$
    by Rally18$ » Thu Jan 14, 2021 7:52 am
    if i read correctly off of Race Tech's website, the stock suspension springs rates are .72kg/mm front and 6.4kg/mm rear. if my conversion is correct, that would be 7.06N front and 62.76N rear. Something doesn't look right........
    could someone confirm or deny this, please?
    Re: Rally stock spring rates
    by JimDirt » Thu Jan 14, 2021 10:32 am
    Yea those numbers are correct , only difference being is you would list it as 0.72kg (not.72 , *just a formality**) and 6.4 , but otherwise , yes the conversion is correct ... I alway have to pay attention when looking at spring rates online to make sure if they are kg. or Nm. when listed , then try to convert it ..... my source was/is https://norwestsuspension.com/convert-spring-rates , as it will give you pretty much any conversion you may run across as far as spring rate values ..... Hope that helped ;)
