Yep, I did that. Then you add a steel plate followed by friction plate and repeat. In total, there should now be five friction plates and four steel plates. To me, the four steel plates seem identical. However, in the parts catalog, one of them has a different part number.https://www.revzilla.com/oem/honda/2018 ... crf250laacWhen removing the Judder setup , you remove the Judder Spring (the thin ring) , the thin friction plate and the thin steel plate , then just install a regular size friction in place of the 3 parts ....
It's pretty clear in the parts diagram. Check out this link that shows the first steel disk as a different part number from the other three steel disks: https://www.revzilla.com/oem/honda/2018 ... crf250laacIf they are all the same size physically (they should be the exact same size) then it should not matter the position , the 450R only uses the single friction plate in place of the Judder Spring , Steel Disk and small Friction Disk , are you sure you are not meaning the Friction Disk has a different # ,??? , the 450 does , and it goes to the front (the last one you install)
