2009 CRF450 runs but wont kick start. NOT VALVES
  • amp625
    by amp625 » Fri Sep 18, 2020 6:18 am
    Alright guys I have a bike that has been a nightmare. I bought this bike not running. After a tremendous amount of work and hours of diagnosis the bike runs great.. when bump started. It will not even fire when trying to kick start.
    I have replaced the fuel pump, top end rebuild, CKP sensors/stator, ECU, and rectifier to get it to where it is today. I have triple checked both timing and valve clearance and there is no issue there. Bike runs like a bat out of hell and idles great after bump starting.
    This may be besides the fact since the bike will run but the kill switch seems to be inop. I need to stall the bike to turn it off.
    Any ideas are much appreciated.
    Re: 2009 CRF450 runs but wont kick start. NOT VALVES
    by JimDirt » Fri Sep 18, 2020 10:53 am
    Have you tried starting it with the Enriching knob pulled ?? (the Idle knob) .... , even though you said Top End Rebuild ..... have you checked compression ??? , if it is low due to ring gap alignment or even a ring upside down , it would still run , but be hard to start
    it sounds like you checked the fuel system ,what about the spark plug ?? was it replaced ?? , have you checked the spark plug cap ??? , it might be giving a weak spark at lower RPM , and I believe they have a resistor in them ,so it could be bad ...... :-k
    The kill switch could be a factor as it is tied into the ECM .... 8-[
