2004 crf 450 lighting
  • gsxr600srad
    by gsxr600srad » Sun Jul 05, 2020 1:15 pm
    Got a 2004 crf 450. Looking to put some lights on it. Been looking for a new lighting stator.. do you need to put a new flywheel in or can you get away with just a higher output one and run some lights. If someone has this setup let me know. Thanks in advance
    Re: 2004 crf 450 lighting
    by JimDirt » Sun Jul 05, 2020 3:32 pm
    Depending on the unit/brand you choose , you should not need a flywheel , just the stator kit , however , some kits require a battery of some sort and a regulator/rectifier , or a battery and a regulator , to run the lights , depending on the output and/or type of lighting used , such as LED or Halogen , turn signals , brake light , horn , etc. .... it all makes a difference on what is needed ...
    I do not have the setup , so can't say firsthand , but the general consensus is , the type of kit you buy will determine what exactly is needed in addition to the stator itself , if at all .....
  • gsxr600srad
    by gsxr600srad » Tue Jul 07, 2020 9:09 am
    Just ordered a lighting coil at 60 watts. Got a led headlight and taillight. Trying to see see what else I need to run them. I'm thinking I need a reg/rec and battery since the lights are dc. Just trying to find the right ones I need. Any ideas would be greatly appreciated
    by JimDirt » Tue Jul 07, 2020 5:57 pm
    Maybe look into this and even contact them and see if you need anything else with it
    https://www.steahlyoffroad.com/honda-cr ... r-l-820105
  • Dirtclod
    by Dirtclod » Tue Sep 28, 2021 6:06 pm
    I run AC no battery on my 04 35 watt headlight LED tail light TrailTech stater and flywheel and reg.
    Color me gone!
Users browsing this forum: No registered users and 11 guests
