Map switch
  • Zackerycrf250r
    Map switch
    by Zackerycrf250r » Thu Jul 02, 2020 4:30 pm
    I just recently bought a 2015 crf250r and the map switch was not working, so I replaced and now the switch lights up once on start up, but whenever I press it to change maps it constant flashes. Any help fixing this issue is much appreciated!
    Re: Map switch
    by JimDirt » Thu Jul 02, 2020 6:01 pm
    Most likely (I am guessing since I don't know exactly how you did it) , you are not holding the button down long enough .... Read this (what I circled , and "stopped means the bike stopped/not moving , but with the engine running) , so you are not just pushing it , but you are holding it for a couple seconds (1 or 2)
    Also , here is a link to the Owners Manual for it , just wait for it to load (it sometimes takes a bit , at least with my connection) then select Year (2015) , Segment (Off Road) , Category (Competition) and Model (CRF250R) , then select Download , it is PDF format so you need Adobe Acrobat Reader to read it , just save it to Your Documents if on a PC , or to whatever download location you use on your phone
    https://powersports.honda.com/downloads/owners-manuals
