Crf250x stator issue
  • corey420
    by corey420 » Sat Jun 27, 2020 8:36 am
    Hey everyone my wife's 2006 CRF250x has stopped charging the battery. I've tried 3 different batteries. The bike runs perfectly fine. Head light works fine when it's running. Tail light was eliminated. It has a new oem starter relay as the previous one failed. I put a new oem rectifier regulator as I tested the previous and it appeared to be dead. I've pulled the tank and seat off and checked over the wiring and connections. I didn't find any obvious issues. I haven't had much time to spend on it as I have to work alot. Figured I'd try asking here for some insight if someone else has had the same issue. Thanks!
    2020 300XCW
    06 CRF290X
    13' KX65
    09 KX65
    04 CRF50
    Re: Crf250x stator issue
    by JimDirt » Sat Jun 27, 2020 1:55 pm
    I don't have a 250X Service Manual (just Owners Manual which does not do Electrical) , the settings "should be the same though , so the easiest way to check , is remove the left side radiator shroud , right above the fuel valve , there should be (on a tab on the frame spar) a Black 4 wire plug , unplug it , and look at the Yellow wire and the White wire , put your meter to continuity test , touch a known ground (battery ground is fine) with the black probe and the red to each of the wires mentioned , and each of those wires at the connector (stator side) should have continuity , if any wire does not have continuity , then the stator is bad , that is the fastest test ....
    EDIT: , I just checked the 250X Manual from manualslib.com , The Honda Service Manual covers from 04-13 , and it is the same connecter and test as the 450X , so this is out of my 450X Service Manual ... so look for this plug and it should tell you if its bad or not , I can also post other tests if needed
