by Dan Diego » Sun May 03, 2020 7:34 pm
No blinking lights. I can bump start the bike and it runs fine. After I shut it off, then for the next several minutes, I can use the kick start successfully. After about 15 minutes or longer, no such luck. When cold, I kicked the bike 10+ times and then quickly pulled the plug. There was not a hint of gas on the plug so I am focused on fuel delivery. Worth noting, when I bump start the bike, I dump the clutch for a second or two it will not fire but then I roll the throttle, the bike fires right up and runs well. I cleaned the fuel pump removed the fuel filter but the symptoms remained the same. I've taken apart the throttle body and in the process of cleaning it and all of the electrical connections and inspecting the wiring. I am going to check the rectifier, condenser, injector, and remaining ignition tomorrow.
