2020 450x plastics
  • Xsnoman
    2020 450x plastics
    by Xsnoman » Fri Mar 13, 2020 6:10 pm
    Will 2020 x plastics fit an 07?
    Re: 2020 450x plastics
    by JimDirt » Sun Mar 15, 2020 12:16 am
    As far as I know .... No .... The platform change to the bike is like the 17-20 R , so frame is different , tank size is different , so I don't see the plastics "bolting up" , however it does not mean you can't take the time to possibly fabricate some brackets to make it somewhat work ... but as far as just bolting them on , and them actually fitting or looking good , probably not , the only thing that might fit is the front fender unless they changed the triple clamps on the X as well , to the new R platform , because they are different on the R/RX and the front fender has different mounting bolt location (I know this because I run a 12 front fender on my 02 450R and the 02 is the same bolt pattern as the 05-17 450X) , but 09 -12 R is different from 02-08 R , then 13-16 , then 17 up is different again .... That is just the front fender ...... , so unless they are making a special front fender using the old bolt pattern with the new style fender (front only) then I don't see it happening , and the rear would be completely different if the new X took the new R subframe , as it is completely different from the 05-17 subframe
    Since the new X is more like the new R , not much will be the same ....I have not looked at them personally to see the actual differences , but I am pretty sure , you won't be directly "bolting" anything from one to the other with the possible exception of the front fender (maybe) ....
