Hi i recently purchased a 2014 crf250r, it came with 2 extra sets of fork springs and i have been trying to figure out what the springs weights are, using one of these spring weight calculators but find it hard to get a consistent accurate reading of the spring dimensions.
Both spring sets are the same height and very close to the same dimensions
one set of the springs coils seems to be slightly looser wound, has numbers printed on the side coils looks to be 280542 1 and possibly 48 on the next lower coil, it has a duller finish and weighs lesser than the other set at 510grams.
The other spring set has no printed numbers or marks on top of the coil, it seems to be slightly tighter wound having maybe half an extra coil winding, it has amore shinier finish to the metal and weighs heavier at 527grams. Could this spring be the standard 46 spring?
The spring set i pulled out of the bike is printed clearly with number and a 50 on the coil below those numbers.
Any ideas would be appreciated.
