Timing 2004 250
  • leecrf
    Timing 2004 250
    by leecrf » Thu Feb 27, 2020 10:46 am
    Just doing a rebuild on my 04 250r
    Is there a good how to link to set up a new timing chain and valve clearances etc i cant find one theres a lot of posts about but cant find the actual walk through
    Re: Timing 2004 250
    by JimDirt » Thu Feb 27, 2020 6:55 pm
    I am assuming you have the correct flywheel puller , etc. to do everything , correct ????
    The process is fairly simple ... Give me a bit and I will post up pictures from the Honda Service Manual , for doing the Timing Chain , and also doing a Valve Adjustment ....... I will try to get it all posted hopefully sometime tonight ..... ;)
    Re: Timing 2004 250
    by JimDirt » Fri Feb 28, 2020 1:42 pm
    Sorry , got sidetracked ...... if you still need the info , I can get it posted up .... if not , no problem ..... 8-[
