Dead
  • 05woodh1
    Dead
    by 05woodh1 » Sat Feb 01, 2020 11:26 am
    Hello everyone, im hoping someone can help me out. I have a 2013 crf 450, bought it as a non runner. Ive replaced head gasket and piston rings, reset tps so its within spec. Valves are within tollerance. Had it running but when it cuts out it wont start again it happened 3-4 timea and now it wont start at all. Got a strong spark and compression so am at a fuel point. I replaced the fuel filter, but still nothing when i kick it over with the injector out i only get a very minute amount of fuel spray out of the injector. And also even without being plugged in fuel dribbles out of the fuel pipe is that right? Ive checked the injector opens with power and it does, i can hear the pump running when i put power to it so am at a loss now. Theres just no pressure.coming from the fuel pipe at all fuel just dribbles out when its.not connected and wont spray when the injectors on? Anyone help me out? One of the main O rings to the tank is missing but thats on order and i wouldnt of thought that would stop the fuel pump working properly? Im ready to set the thing on fire now so any jelp would be great 😁
    Re: Dead
    by Back2-2 » Sat Feb 01, 2020 2:42 pm
    Hello, If I recall there was someone with the the exact same issue and when he replaced the o-ring you described it fixed the low pressure issue. When you get the o-ring all will be golden.
    Let us know if that does fix the problem.
    Good luck.
  • 05woodh1
    Re: Dead
    by 05woodh1 » Sat Feb 01, 2020 3:49 pm
    Good luck.
    Cheers i think ive read that one....the i ring he replaced was different the one im missing is one if the large ones between the tank and fuel pump so not sure that would cause it? Surely it the fuel gets pressurised and not the tank? Will be replacing it anyway for peace off mind!
    Re: Dead
    by Aussiecrf230 » Sat Feb 01, 2020 3:52 pm
    The o ring is designed to keep something in or something out.
    I would hazard a guess your fuel pump is sucking air.
  • 05woodh1
    Re: Dead
    by 05woodh1 » Sun Feb 02, 2020 6:45 am
    Had power at fuel tank and pressure when connected up to 12v. Took stator cover off and found one of the pick ups not fully connected so think this is my problem
    Re: Dead
    by Back2-2 » Sun Feb 02, 2020 7:12 am
    Excellent. That's a new one on me. Thank you for updating us on your findings.
  • 05woodh1
    Re: Dead
    by 05woodh1 » Sun Feb 02, 2020 11:53 am
    Cant post a pic for some reason as every photo is too large.
    Re: Dead
    by Aussiecrf230 » Mon Feb 03, 2020 2:25 am
    You are using a photo hosting site like imgur?
  • 05woodh1
    Re: Dead
    by 05woodh1 » Wed Feb 05, 2020 1:35 am
    Ive put the images on there of one of the pick ups
