Cleaning of centrifugal oil filter
    Samanjo
    by Samanjo » Fri Jan 03, 2020 10:48 am
    Please help.
    The bike is getting close to another oil change and I want to clean the centrifugal oil filter at the same time.
    I have not done this when I bought the bike about a year ago.
    Must I make use of an impact driver to loosen the bolts or is it possible to loosen the bolts with a normal Phillips screw driver?
    Re: Cleaning of centrifugal oil filter
    by Aussiecrf230 » Fri Jan 03, 2020 2:41 pm
    I wouldn't panic as it takes a while for them to clog up.
    You will need a clutch cover gasket and if memory serves me corectly you need the special tool to undo the pump cover.
    I am on holidays at the moment but will be back home in a week and can grab the info you need.
    You can change the oil seperate from cleaning the filter by laying the bike over like when changing a clutch.
    Samanjo
    by Samanjo » Sat Jan 04, 2020 4:16 am
    Thank you Ray
    I bought the bike from a farmer who purchased it new (2010) and he always sent the bike to his auto mechanic for annual servicing.
    The farmer could not tell me whether the centrifugal filter has ever been cleaned and he never provided me with a contact number of the mechanic.
    I don't have an impact driver hence my question whether a normal Phillips screwdriver will also work.
    Someone has a service manual for me but I can only pick it up during February
    by Aussiecrf230 » Sat Jan 04, 2020 8:19 pm
    I will be able to dig out the information you need to service it.
    I have a service manual but not sure how well it will scan.
    Will post up when get home.
    Samanjo
    by Samanjo » Sun Jan 05, 2020 9:52 am
    That will be great, thank you Ray
    by Aussiecrf230 » Tue Jan 14, 2020 6:49 pm
    Hi Samanjo,
    Sorry for delay had to do a bit of work when I first got back.
    If you change your oil regularly you will find the slinger filter stays pretty clean.
    Have seen 10 year old XR200s with little residue.
    If you wear a clutch out you should clean it out at the same time.
    You have to take it off to get to the clutch anyway.
    If you clean it now it should be good for a year or two at least.
    This shows you the insides and the torque figure for the slinger screws.
    WARNING: from the factory they were put in dry and pretty tight.
    Use a JIS screw driver NOT a Phillips or you will strip the heads for sure.
    An impact driver with a well fitting bit (Pozidrive can work) is useful in getting a good grip only - NO HAMMER.
    Be very gentle tightening them back up if you don"t have a low value Torque driver so they don't strip the housing.
    If you do kill the heads of the screws three metric allen screws can be used to replace them.
    Some people order the 3 screws when the order the gaskets.
    You will need the Clutch side cover gasket as well as the Slinger gasket.
    If you can afford the Socket tool to remove the slinger base it will be easier to clean separately.
    This is the same tool for the Clutch hub nut and is used on lots of the small XR and CRF motors. Think it does steering stem as well. So pretty useful.
    From memory it is the larger end of the factory tool.
    After market ones are available.
    Hope that helps and if you have further questions just ask.
    Samanjo
    by Samanjo » Fri Jan 17, 2020 10:26 am
    Hi Samanjo,
    This info will definitely help, thank you Ray
    Appreciate your assistance
