NEWBIE with big ambitions
    by [email protected] » Sat Sep 21, 2019 9:56 am
    I'm 35 and getting back into bikes after a 15 year absence. I just recently purchased a 2004 450CRFr. I plan on doing a Timbersled conversion eventually.
    Before I get going on the conversion I need to cover some basics. During the maiden voyage (30 miles of single track in CO) I lost my front caliper bolts and some other key components. Needless to say I need to do a once over on everything. She runs great and kicks over no problem. The original owner replaced about every single factory part with aftermarkets and did some mods on the engine. I have no clue what all he did. He also installed a front and rear light to make street legal. I have the manuals, tools, and a place to work. I just need a little guidance.
    Here's the list of things I plan on covering, please comment or add input.
    Possible chattering magneto and light dims significantly with low RPM's.
    inspect all bolts, use loctight
    Basic maintenance on chain, air filter, oil, cables
    Look into battery and electric start
    redo fork seals
    Re: NEWBIE with big ambitions
    by JimDirt » Sat Sep 21, 2019 11:01 am
    From what you described , it sounds like either a bad Stator or Flywheel magnet , or possibly a bad Ground or connection OR , a bulb output that is greater than the capacity of the Lighting Coil output in the Stator ......
    You need to determine the brand of aftermarket Stator and light kit (hopefully they are both the same brand and are compatible with each other) , next you need to confirm ALL connections are good (not loose) and that all Grounds are secure and tight , as a bad ground will backfeed thru the system and cause all sorts of symptoms ..
    As far as your "Checklist" ...... I would take some time and go over ALL bearings , which include the Steering Head bearings , the Swingarm bearings , and Suspension Linkage and Wheel bearings .... This is a must do , and should be done EVERY season before riding .... Along with checking the valves (do that now) as well as inspect the clutch Plates for wear and the Basket for grooving .... , the 04 should have enough power to pull the Snow Bike kit in stock form .....
    As far as the "chattering" goes , I would suspect it is either the Timing Chain and/or the Tensioner causing the noise you are hearing (there should not be any vibration along with it) , if there is a distinct vibration , I would refer back to the Flywheel as a source , possibly a Magnet coming loose throwing the flywheel out of balance ..... DO NOT attempt to remove the flywheel without the CORRECT flywheel puller made for your bike (even different CRF models use a different puller like the X and R) and make sure you use it correctly , if you crush the brass flare that is on the end of the crankshaft , you will ruin the crank and need to replace it , as you will lose oiling to the engine if it gets damaged , the little cap that goes over the brass end at the end of the threads that come with the Flywheel Puller needs to be put on lightly and not bottomed out , screw it on all the way , but then back it off slightly so not pressure is put on the brass flare , leave a slight gap between it and the brass piece so it is not crushed when tightening down the puller
    As far as Battery and E-Start , the E-Start is not going to happen and X cases will not fit in your frame unless you have the frame cradle modified , and even then , it would be cheaper and better to just get a 450X , but you can use (if the kit is equipped for it) a battery to help power the lights , but the kit must be made for one , don't just install one and try to hook it up to your electrical or you will fry your electrical system ..... the battery it will most likely use is similar to a RC Car battery (6 C-cell Ni-Cad batteries)....but check the schematic for the aftermarket Stator and Light system to make sure it will accept one ....
    Also , you do not really need a lighting kit , so there is the option of just removing the lights or just that kit if you can't get it working right , and just get a new one from Trail Tech or similar place that has one made specifically for your bike and needs (output amps , etc.) if you do really want/need the lights to work for evening trail riding and or snow riding getting back late to camp ..
    Hope that helped some .... ;)
