CRF 250 Rally slipping clutch
  • Kalborger
    by Kalborger » Fri Sep 20, 2019 7:00 pm
    Noobie, what are the parts that i need to replace as mine is already slipping.
    If i dont change, what will happen bad to our bike?
    I felt mjne slipped around 8000km, is it normal to slip around that?
    TIA
    2018 CRF 250 RLJ
    Re: CRF 250 Rally slipping clutch
    by JimDirt » Fri Sep 20, 2019 9:36 pm
    You did not mention what year it is :-k
    But basically , you would need to change the clutch plates and disks as a set at the very least ....
    As far as them slipping at 8,000km , it honestly depends on how it has been ridden , if you are slipping the clutch in heavy traffic , then I would expect the clutch to go bad sooner than what what would be considered "normal" , if you are riding open roads and not sitting in traffic , then no , it should not have gone bad already ...... As far as what it will do , it will eventually ruin the clutch basket , which will be expensive , as well as the constant slipping will overheat the engine and cause other issues related to overheating , so you want to take care of this as soon as possible .... , I would drain/change the oil and filter as soon as possible as the oil will be in need of changing especially if the bike has been overheating ....
  • Kalborger
    by Kalborger » Fri Sep 20, 2019 10:55 pm
    Thanks man. Damn, i just changed my oil fully synthetic.
    Yeah, Manila always experience heavy traffic... Always gripping that clutch with gear 1 in position. hopefully, none wrong happened with the clutch basket. Buy everything is relly helpful, thabks.man.
    2018 CRF 250 RLJ
    by JimDirt » Fri Sep 20, 2019 11:20 pm
    Yea , no problem , yea city streets are tough on bike clutches ....
