2006 Honda 250
  • Kenny07
    2006 Honda 250
    by Kenny07 » Thu Sep 19, 2019 1:09 pm
    Had to change the shifter so took the entire bike apart. Got it all back together and it won’t kick over. Checked compression, spark plugs, valves, fuel intake, basically everything I can think of. Honda is also stumped. Any suggestions?
    Re: 2006 Honda 250
    by JimDirt » Thu Sep 19, 2019 4:39 pm
    You have me a little confused here .... You said you had to change the shifter ..... Why would you need to take the bike apart to change the shifter ??? , its 1 bolt and it slides off :-k 8-[
    Are you meaning you had to take the Shift Drum , or shift shaft , or shift fork out in the transmission ???? , that would make more sense
    As for your issue , I would suspect you have inadvertently missed plugging in a connector somewhere ..... it is highly possible when you removed the gas tank , you accidentally pulled off the power wire that goes to the coil with the fuel valve when pulling the tank out , , with the tank off look and see if its unplugged , I think that will be your problem ... ;)
  • Hammer
    Re: 2006 Honda 250
    by Hammer » Sat Oct 05, 2019 5:45 am
    An update to see if you fixed it please.
    If you can't ride good, then look good riding
    In the morning, we ride.
    2020 crf250r
    04 crf 250, power now, Icat, full fmf ti exhaust, hot cam. Tom Morgan ported head,New ti valves, springs.
