Help please with a CRF70
  • robbrown1957
    by robbrown1957 » Thu Aug 08, 2019 7:46 am
    Hi everyone. Hope someone can assist. Bought a well used and in need of serious TLC CRF70f. After a lot of tidying up and adjusting, I got it running however occasionally the fuel leaked out of the carb overflow.
    I have stripped and cleaned the carb a few times however cannot stop the leak. I think it could be the needle that is operated by the carb float assembly. I have had the needle out and cleaned off some grime that was stuck to it and cleaned the whole assembly with brake cleaner fluid however the problem persists. I noticed on the needle shaft that there were 3 raised splines for want of a better word though could not spot 3 grooves in the pot that shaft sat in for them to possibly locate into. Should these 3 shaft splines line up with 3 pot grooves and is that why my carb is overfilling do you think. Any tips greatly appreciated.
    Many thanks
    Re: Help please with a CRF70
    by JimDirt » Thu Aug 08, 2019 10:57 am
    Could you post up a picture of what you are referring to ???
    To post a pic you need a hosting site like IMGUR or such , you will paste the link in your post and it will show up
    https://imgur.com/
    Your link will look like this in the post:
    [img]https://i.imgur.com /yLR1FNo.jpg[/img]
    But show up like this:
