by JimDirt » Tue Aug 06, 2019 11:55 am
Yes and no , you are looking for a certain amount of resistance , not just resistance , the link/s I provided in my prior post gives the measurements you need to worry about to see if your ignition system is working correctly or not , if it falls within those specs , then it is fine , if it does not , then its not , simple as that .... too much resistance is just as bad as not enough , it has to be within certain parameters to work
