Yea , try turning up the idle a bit , these new CRF's do not like low idle , if it was set too low from factory , that might solve the issue ..... , so turn it up a bit , test , then repeat a couple times , see if it gets better each time , if so , then that was it .... you also may go to Honda and buy 1 single clutch disk and remove the Judder Spring setup , it is notorious for causing low speed stalling , basically you will remove the judder spring and plate and disk (3 parts) and replace it with just a regular disk (the parts guys at the dealer should know about this and give you the correct part) , doing both those things "should" eliminate your issues ..... Report back with findings .....Thanks jimdirt I’ve sorted it now and got it to seal.unfortunately that wasn’t the problem. The bike bogs and stalls on a low blip of the throttle. Any ideas where I should be looking?
