CRF fuel tank solution
  • Csdcraig
    by Csdcraig » Wed Jul 24, 2019 7:47 pm
    =DD Toggle Navigation
    There's a 2008 crf 230f fuel tank that is supposed to fit down to 2003 & up to 2015 if you want to change to upgraded plastics of 2008 crf 230f all mounting looks the same for mounting the tank the only thing that is different is the mounting holes on a tank for the Plastics. Because as you know fuel tank shrouds are hard to get for the 2003 all the way up to 2007
  • Csdcraig
    Re: CRF fuel tank solution
    by Csdcraig » Thu Jul 25, 2019 1:58 am
    item# for fuel tank 17510-KPS-A10 2003 - 2015 only thing will be needed is different Plastics.
    by Aussiecrf230 » Thu Jul 25, 2019 3:16 pm
    Thanks for that solution to being unable to source plastics for the early models.
