Issues with my air filter. Any help?
    Baco
    by Baco » Thu Jun 06, 2019 5:24 am
    Hello! I'm new to this forum. I need to replace the air filter on my L300, but I can' t get the damn cover off of the air box! The manual says to disconnect the inlet hose that leads to the engine from the air box cover, but I couldn't get the two apart. Even with the clamp completely loose it felt as if I would end up ripping the tubing in order to remove it from the cover. Has anyone else had trouble with this? I sure don't want to pay someone just to change my air filter. Is the tubing tougher than it seems? Any insight would be much appreciated!
    Re: Issues with my air filter. Any help?
    by JimDirt » Thu Jun 06, 2019 8:14 am
    Are you talking about a L300 Van ??? , if so then I think you signed up for the wrong forum .... This is a Motorcycle/ATV forum , not a Automobile forum ....... and not sure anyone here could give you a helpful answer ....... :? 8-[ :-k
    by Aussiecrf230 » Thu Jun 06, 2019 4:34 pm
    Wasn't the L300 an early Russian motorcycle. Is this what you are referring too Baco.
    by JimDirt » Thu Jun 06, 2019 6:44 pm
    Ray .... When I did a quick Google search it came up with this , which is why I asked if he is in the correct forums
    https://www.topspeed.com/trucks/truck-r ... 31883.html
Users browsing this forum: Google [Bot] and 7 guests
