2016 450r specs
    helmut
    2016 450r specs
    by helmut » Fri Apr 26, 2019 12:50 pm
    Hello all,
    I just bought a 2016 450r that did not come with the owners manual. I have the Service Manual on order, but want to change some fluids etc. in the meantime. Our other 450 is a 2006 and don't want to make any assumptions. Could someone please tell me what your owners manual says for:
    *motor oil, type,weight & qty (in metric) conventional or synthetic
    *same for the transmission side
    *tire pressure, front and rear
    *chain slack (metric)
    Thanks in advance,
    Tom
    Re: 2016 450r specs
    by JimDirt » Fri Apr 26, 2019 8:58 pm
    Engine: .... 0.66 qt/cc with filter
    Transmission: ..0.68 qt/cc
    Tire pressure is relevant to the tires themselves and the terrain your riding , but generally 12-15 psi depending on the situation (soft for sand , harder for hard pack and big jumps (recommended 15 psi according to manual)
    Chain Slack is going to be between 30-40mm at the rear of the guide
    Hope that helped ;)
