2014 CRF250R intermittently dies at low RPM
  • robman
    by robman » Thu Mar 07, 2019 9:31 am
    My bike has at least 100 hours on it that I have tracked doing mostly trail rides. I have kept up with maintenance, oil is never dirty and bike is never overheated.
    Symptom: You can hear it in this 30 second youtube clip https://www.youtube.com/watch?v=cvqkjy6PxN8. About 15 seconds into the clip I can feel the bike is losing power, I try to "rev out" of it a bit but it dies just the same. This also happens sometimes when I come to a stop with the clutch fully disengaged. This happens 1-4 times over the course of 2 hours of riding and the bike always starts right back up and the bike pulls really hard. Otherwise there are no problems with it.
    Troubleshooting so far:
    1. New Spark plug, the old one had a rusty nut but looked okay otherwise
    2. New CLUTCH
    3. Valve Clearance: I checked valves, only one exhaust valve is out of spec and only by .001". The other valves are all within tolerance.
    4. Carbon Buildup: I scoped the piston and it was pretty caked with carbon. I did an MMO piston soak and ran it hard, this cleared almost all the carbon from the top of the piston, I can't see the valves but I'm sure hit helped a bit there.
    5. The MIL light is not showing any codes when I start the bike but I haven't looked at the light as it's dying.
    6. Fuel: I've removed the fuel tank and carefully poured it's contents into another container. I found no debris and the tank looks clean.
    7. Air Filter: Replaced
    8. Exhaust: No Restrictions
    Could one valve being .001" out of tolerance cause this? Could Carbon? Does this sound like a problem with EFI like maybe it's getting too much fuel or not enough?
    Please help, I'm lost and I don't want to just start throwing more parts at it without some proof of failure.
    Thanks in advance!
  • Loganschultz64
    Re: 2014 CRF250R intermittently dies at low RPM
    by Loganschultz64 » Fri Oct 02, 2020 3:41 pm
    Did you figure this problem out? This is exactly what is happening to my 2014 CRF250r. Thank you much..
  • S777
    by S777 » Fri Nov 05, 2021 10:57 am
    Did anyone find out what the issue was? Im having the same problem ;(
    by JimDirt » Fri Nov 05, 2021 8:13 pm
    Welcome to the site S777 ! \:D/
    I am wondering if this is a stator issue .... (guessing with the prior posters as well) , if it was a fuel pump issue it would always die at low RPM , to be intermittent , would lead me to believe it is a electrical issue .... , so I would do some testing with the stator ... hopefully you have a Service Manual , for all the tests and specs .... I only have a Service Manual for 04-09 , so that would not help ...otherwise I would post the specs ... but that is what I would look at first .....
