New To Me '15 CRF230F
  • FilthyPlumber
    by FilthyPlumber » Sun Feb 24, 2019 8:58 am
    Hey there ladies and gent's, just picked up a new to me 2015 CRF230F from a friend. He bought it for his wife and she only road it a couple times and I finally convinced him to sell it to me. Probably has about 10 hours on it. It's completely stock except for the FMF PowerCore 4 pipe. Has't been ridden in 2 years so I plan on doing a full service on it including checking the spark plug, draining the tank, new fuel line, clean the carb (and probably re-jet while I have it out), change the oil, check the brakes, lube the chain and replace the air filter.
    Anything else y'all think I should do before I hit trails?
    I'm planning on putting a shorty cluth lever, bark busters and re-jet the carb and then just have fun. :D
    Livermore, CA
    2015 CRF230F
    86'd snorkel
    FMF PowerCore 4
    +600-2400'
    40-95*F
    45 pilot
    132 main
    Clip in 4th position
    Featherweight lithium battery
    Re: New To Me '15 CRF230F
    by Back2-2 » Sun Feb 24, 2019 3:16 pm
    Sounds like you have a good plan. =DD
    Take your time checking out the carb - hopefully it did not sit with fuel in the carb. Otherwise for the brakes it should only be a fluid flush and good as new. A manual is definitely a good thing to have while doing your maintenance.
    Have fun working and getting to know the bike - then go ride it and have fun. :D
    by Aussiecrf230 » Sun Feb 24, 2019 3:55 pm
    Since it has had a little riding time I would spray your favourite anti seize (kroil, wd40 etc) on to the spoke nipples and give the wheel a spin to work it into the threads. Next day work the nipples back and forth to ensure they are free. Might have to tighten them a little and evenly now they have bedded in.
    Just check the axle nuts and sprocket nuts are still tight. General maintenance stuff really.
  • FilthyPlumber
    by FilthyPlumber » Tue Feb 26, 2019 8:55 am
    Thanks you two.
    I've been doing a lot of reading about the rejet.
    Im fairly certain I'm going to get the CRFSONLY kit and include the fuel screw stuff. I ride from 600 to 2400 ft with temps from 40 to 95*F most often and I think the 132 Main with 45 pilot will suit me well (and the 135 comes in the kit too). Unless anyone thinks I should go with the 135 main with the FMF pipe?
    I was looking at batteries (current one is dead as dead can be) found one called a Featherweight. No reviews but it's sold by a couple different places. Only weighs 0.9 lbs. Does anybody have any experience or heard anything about them?
    Livermore, CA
    2015 CRF230F
    86'd snorkel
    FMF PowerCore 4
    +600-2400'
    40-95*F
    45 pilot
    132 main
    by Back2-2 » Tue Feb 26, 2019 4:16 pm
    If the battery is that light it is probably a lithium Iron. Price will tell you. They lithium iron batteries are fine, light weight and long lasting. They are usually just quite a bit more expensive then lead acid or AGM batteries.
    One thought I had was - If the bike was sitting but the fuel tank and carb bowl drained before sitting you may be able to just add fuel and be good to go. I just brought a Yamaha YZF450 out of storage for 10 years. Added fuel and a new battery and it fired right up and ran fantastic. The only thing I did before storage was drain fuel and added a slight amount of preservation oil to the carb.
    Good luck with the de-hibernation. Isn't fun to work on your bike! :D
