clutch not fully disengaging
  • o7crf450r
    by o7crf450r » Mon Sep 10, 2018 6:36 pm
    Ive got an 07 crf450R, I was having issues with the clutch so I swapped out the clutch plates.
    Now when I pull the clutch it doesnt fully disengage, cables are tight, I replaced the springs and plates with the same ones that were in there.
    It seams like the Lifter rod Isn't pushing the pressure plate far enough???
    Re: clutch not fully disengaging
    by Aussiecrf230 » Mon Sep 10, 2018 6:48 pm
    Were there any grooves on the basket where the plates slide?
    Nine out of ten times this is the problem.
  • o7crf450r
    by o7crf450r » Thu Sep 13, 2018 1:50 pm
    basket is good, Groves are starting but ive had much worst.
    the pressure plate just wont push out.
    by JimDirt » Thu Sep 13, 2018 2:49 pm
    It is possible that the actuator lever has somehow lifted slightly and the push rod has slid under it which means it would not be moving when the actuator does , it would then not be able to push the lifter rod far enough to disengage the clutch plates , so what i would do is move the actuator (with the clutch cover off so you can see what its doing) , and see if it pushes the plunger out any , , if it does not , remove the clamp that holds down the actuator where the cable connects , then lift the actuator a bit , then try to pull the rod out a bit and then push the actuator down as far as it will go , then push the rod back in and turn the actuator again , and see if the rod moves now , if so then put the clamp back on and make sure it is holding the actuator down all the way and there is no upwards movement if there is a gap/slop , then bend the clamp down so it holds the actuator tight down (so it has pressure on it), hopefully that solves your issue .... 8-[
  • o7crf450r
    by o7crf450r » Fri Sep 14, 2018 4:42 pm
    Thanks man, I didnt even think to check the actuator. Took it all apart, the actuator had a ton of play and was super worn down so I replaced it and the lifter rod, seams to be working.
    by JimDirt » Fri Sep 14, 2018 5:02 pm
    Glad it worked ;) , yea , most people go straight to the clutch itself for answers , and forget there are other parts that affect how it functions as well :lol:
