HELP! Coolant leak near bottom corner of radiator
  • OTGreen
    by OTGreen » Tue Jun 26, 2018 7:49 am
    Hi guys,
    New to the forum here (and a new CRF250L owner) hoping to gain some knowledge on what might be causing my bike to overheat.
    I laid it down last week on its left side, where the radiator is, really not hard at all though, but in a rocky area. Noticed some coolant leakage but brushed it off when I was done riding. Went to ride last night and after 5 minutes going up the mountain the dash showed a high temperature light on the dash. I looked down and noticed blue coolant on the bottom of the radiator only, specifically from the left side of the radiator, right where impact would have been when I dropped the bike. Not dripping, but slowly oozing around the bottom of the radiator. Noticed some sluggish acceleration too (hoping these symptoms help).
    In the photo, I've circled exactly where I am seeing the coolant.
    What do you all think is the cause? Did I crack the radiator? I looked for a hose leak and didnt really see one. Any other ideas?
    All information and help would be much appreciated!
    Re: HELP! Coolant leak near bottom corner of radiator
    by JimDirt » Tue Jun 26, 2018 8:25 am
    The first thing i would check is the radiator hose going to the the bottom of the radiator shown in the pic , it looks to me to be a bit down on the pipe , from looking at other hose connections in a Google search , they seem to be higher , not saying that is the issue , but its a possibility just because if it is slid down , it would be loose enough that when the radiator is under pressure when up to operating temp , the hose could seep or even squirt up to the radiator where your seeing the fluid , see if it twists on the pipe and/or if the hose clamp is tight
    Otherwise i would try to flex the radiator by grabbing it by the lower tank , and see if you notice any seepage (do this when the bike is warmed up with the fluid topped off and so there is pressure in the tank) , as it could have been damaged along the seam of the tank , or where the core attaches to the tank , as i can't see any real obvious physical damage in your picture (is the radiator twisted at all ?? ) , what you might do is take it to your local radiator shop and have them pressure test it , this will bring out any leak it may have , and then you can either have them repair it , or buy a new radiator (you can get one here or at your local dealer) , but i would start with the hose connection first , then go from there , as i have seen some really smashed and twisted radiators that do not leak ,, so its possible that in the crash/fall , it got caught and pulled the tank away from the core without obvious damage , but enough to compromise the soldered connections
    Hope that helped 8-[
  • OTGreen
    by OTGreen » Tue Jun 26, 2018 9:11 am
    Jim Dirt, thank you so much for helping me out!
    Few more questions: So you are saying in the bottom left corner of the picture, the soldered connection right there could have been pulled apart? That might make sense as that is where i see the coolant drips from or oozes from, but I thought that may be only because that is the side of the kick stand and gravity is pulling the fluid in that direction.
    I will check the hoses per your suggestion and tighten them down if loose. I did notice that when I squeezed the bottom hose, I did see some fluid ooze out. That shouldn't happen right? Ill try to tighten more if i can.
    Any one else with ideas please feel free to chime in! This is great help. Much appreciated.
    by Back2-2 » Tue Jun 26, 2018 12:09 pm
    Clean the entire area and run the bike. Watch very carefully and you will see a leak show if there is one. If it is only happening after the bike has sat statically then and when you squeeze the lower hose it is a clamp issue and an easy to resolve problem.
    by JimDirt » Tue Jun 26, 2018 3:17 pm
    Basically where the thin tubes meet the bottom tank , where you have it circled
    No it should not leak ANY fluid when you squeeze it , that is a indication that the hose and/or hose clamp is loose
    What Neil suggested about cleaning/washing the bike off and drying it to make sure there is no coolant left over , so you will be able to confirm where the actual leak is , is also a excellent suggestion to narrow down the leak location
  • OTGreen
    by OTGreen » Fri Jul 27, 2018 10:52 pm
    To follow up here...
    My radiator was cracked pretty bad behind the fan, i couldnt see it without taking the fan off.
    Got a new one instead of messing with repair. Fixed her up tonight.
    Thanks for the help folks!
    by JimDirt » Sat Jul 28, 2018 5:50 am
    Glad to hear you got it resolved !! =DD
