Sweet thanks! Is a YouTube video ok to go off of? And the manual obviWelcome to the site !!
It is sounding like it could be the valves , you need to check them , it's not that hard to do , just remove the Seat , Gas Tank ,Valve Cover , then get all the marks aligned , there are 2 notch marks on the cam sprocket , like this - - , they need to be level with the head and a arrow behind the cam sprocket , the cam lobe needs to face backwards at about the 2 O'clock position when looking from the ignition side(shifter side) , then behind the small round plug on ignition cover , inside hole is a notch , it needs to be aligned with mark on Flywheel , then on the clutch cover there is a large round plug , in the hole on the front side is a arrow and on the gear is a dot , those need to be aligned ALL at the same time , this will indicate TDC , you can then check your valves
Intake: 0.12mm (plus or minus 0.03mm) or equal to 0.005 in. (plus or minus 0.001 in.)
Exhaust: 0.28mm (plus or minus 0.03mm) or equal to 0.011 in. (plus or minus 0.001 in.)
Report back with findings , and we can go from there![]()
Now how hard should I slide the feeler gauge in there? Should I cram it or take it easy to where I feel a little resistance but not too much?Yes , just make sure all marks are aligned , as that is important to get a correct measurement
Ok so should I measure when the cup is on it or not? By the cup I mean where the cam hits when the engine is together, that little upside down cup. Or measure without the cup on it?Yes , just slide it in , when you get slight resistance but it moves in and out easily , that is where it should be for correct gap reading , if you force it , you are essentially pushing the valve stem down (under the cup) and you will not be accurate
Basically as if you were pinching a piece of paper between your index finger and thumb , then slide the paper thru the fingers , you want enough resistance to keep the paper in your fingers , but not tear it
Hey I tore it apart, shimmed. Put nothing has changed. What else?Yes , just slide it in , when you get slight resistance but it moves in and out easily , that is where it should be for correct gap reading , if you force it , you are essentially pushing the valve stem down (under the cup) and you will not be accurate
